DP ULTIMATE CG
Since we are the subject, I have a similar question. I too am putting together a DP Ultimate and am thinking of installing the fuel tank over or near the CG. Since the CG won't be changing as the fuel is consumed as it would if the tank was mounted just behind the firewall, do I need to change the location of the CG, or would the stock location be ok? Thanks
Russ
Russ
My Feedback: (19)
Go for the 3/4" to 1/2" mark. I cut a hatch in mine to get the battery as far back in the tail as it would go. You will run out of elevator at the nose heavy cg while landing
