funtana questions
VA
Does it seem like a 14 x 4 prop is not enough pitch? I need some help with the arebatics too, spoilerons for anything besides a parachute? How long should I be able to stay in the air before running out of fuel right now it is new so I am still a little rich but I am only getting about 7 minutes flying. Did anyone need to do much ajusting to the low idle needle on the Saito 72 if so about how much? Thanks to anyone that can give me some help.
Runing a 13 x 4W on my 72, but only using 20%. Plenty of speed. Don't think this plane would like fast. Using the stock tank? Keep my timer set for 10 minutes, but kept it up over 18 the other day. Didn't check the tank but it landed running. How much time have you got on the engine? Start leaning out the low end, just make sure the transition is good. It will take a few gallons to get it running its best.
Still playing with the flapperon/spoileron thing with this plane and have not settled on what works best for what yet. Almost dumped it the other day trying a low blender with spoilerons on. I had them at 100% mix. Think about 20% might be good. Have not programmed in the snap flapperons/spoilerons yet.
Ed M.
Ed M.
IL
http://saito-engines.info/
VA
Mine is only running about 9 minutes right now, but again I had been running it very rich. I leaned the high idle out now and just last night leaned the low in about a 1/4 turn. If mine idles much under 3000 it cut off yesterday. I am going out again today I guess we will see. Thanks
![](/forum/images/badges/premium_vendor.png)
My Feedback: (9)
I have spoilerons set at 100% on a switch. You have to be able turn it on and off. The work great for elevators and the wall. The elevator this thing will do is unreal. Mine drops straight down inverted and flat. At high idle it even goes nose up but also pulls the plane forward.
The 4" pitch prop is perfect for this plane. Your .72 might have a better time with the 13*4W so try both.
later David
later David
IL
VA
Run about a gallon of fuel through before you adjust too much
