CG ON SEAGULLPC-9
NEED HELP
I KNOW THE INSTRUCTIONS SAY 8CM, FROM LEADING EDGE, BUT I CAME OUT CLOSER TO 9CM HATE TO PUT LEAD IN,CAN I FLY IT WITH CG AT ALMOST 9CM? AND IM NOT SURE OF THE CONVERSION TO INCHES. WOULD LIKE TO HEAR FROM SOMEBODY WHO HAS THE FLOWN THE MODEL.
THANKS
LEN
THANKS
LEN
My Feedback: (68)
Here is the info you need, I converted it for you using an online tool I found
Hope it helps
Here it is for future use: [link=http://www.sciencemadesimple.net/EASYlength.html]Conversion Tool[/link]
9.000 centimetre [cm] equivalent to: 3.54330 inch [in]
matt
Hope it helpsHere it is for future use: [link=http://www.sciencemadesimple.net/EASYlength.html]Conversion Tool[/link]
matt
what engine are you using?
I have this plane and have a 46FX up front and it balances perfectly at 8cm. I don't even have the Rx batteries up at the very front...It could go another 5 cm forward if needed.
Do you have the batteries pushed as far forward as they'll go and your receiver right up there behind it...?
It's a lovely plane to fly...I think it's a fantastic plane.
It's my first low wing and it'd very stable i feel...Possibly more stable than my trainer!
I was flying it bout 2 hours ago and it was very windy - when i took off it went straight into vertical and hover at bout 3/4 throttle and then i managed to get the nose down to level after a lot of panicking trying to get it to full throttle and concentrate on the tilting of the plane etc!
I just trurned to my friends and said that i was just trying to hover! lol I was lucky
THANKS FOR YOUR REPLYS.
I CHANGED THE FUEL TANK.AND LOWER IT SO IT WOULD LINE UP WITH THE CARB BETTER, PUSHED EVERTHING AS FAR FORWARD AS I COULD. HAVE A TOWER46 FOR GO. WHAT I WOULD LIKE TO KNOW.IF THE CG IS BETWEEN 8&9 CM WILL IT FLY OK. HAS ANYONE FLOWN IT WITH THE CG BACK A BIT.
THANKS
LEN
THANKS
LEN
