 carl goldberg decathalon -elevator setup >
Old 11-16-2003 | 01:11 PM
Default carl goldberg decathalon -elevator setup
I picked up my new carl goldberg decathalon 60 yesterday and was quite impressed with everything. It is a beautiful looking plane and I know I will like it. I'm planing on putting a 90 magnum 4 stroke that I have in it. The only thing that I find questionable is the method used for the elevators. They use a yoke wye system. Has anyone found this to be a problem? If so what method did you use in your decathalon. Thanks, Flybye[8D]
Old 11-16-2003 | 09:27 PM
My Feedback: (13)
Default RE: carl goldberg decathalon -elevator setup
There are no problems with this system, if several caveats are followed.
One bizarre thing I have noticed, on two ARFs now- one a Goldberg Ultimate, which is my current project- is that "they" tell you to hook up the pushrod at the servo end when it is offset; IOW, not centered in the fuselage. This is to allow the center servo position to be used for a pull-pull rudder control, but it also introduces differential throw on the elevator, as one side will moving farther than the other.
It doesn't take a nuclear physicist to figure this out, so I have to wonder...
Anyway, the fix is easy. Below is a pic of how I did it on the Ultimate. I fabricated a similar set-up on a H9 CAP 232 quarter scaler, but used "store-bought" components mostly- a Nelson bellcrank, DuBro connectors, etc. The one below was fabricated from stuff in my junk box. It is a bit cluttered in there, but you can see the elevator pushrod coming to the appropriate servo over the rudder pull-pull bellcrank- which was made from a Dubro heavy duty servo arm. That's how to get the necessary central location for the elevator pushrod and rudder bellcrank; vertical displacement.
I suspect the CG Decathalon has a similar set-up to the Ultimate that will need this treatment...
Just remember to keep the two sides equal in length and the bends the same angles, run the servo hook-up point in the center of the fuselage, and you'll be fine.
Old 11-16-2003 | 09:29 PM
My Feedback: (13)
Here's a look at the business end...
Old 11-16-2003 | 09:53 PM
Steve --I like the method you used and the pics are sure helpful. Thanks Flybye
