 Funtanna >
Funtanna
Funtanna
Old 11-23-2003 | 09:00 PM
Default Funtanna
I am going to be putting my Funtanna together soon and was wondering if there are any modifications i should do vs just following the recomended procedure in the manual. I did a search and didn't see anything but I thought I might ask before beginning construction. I will be powering this plane with an OS 70 Surpass.
Old 11-23-2003 | 09:12 PM
Default RE: Funtanna
Try "Funtana" with one "n" in the search box. You should find a ton of info.
Old 11-23-2003 | 09:39 PM
If you are using a 2 stroke, you will most likely need a Pitts muffler. One other thing I did was move the throttle servo to the opposite side and had to use a flexible control rod for it to get around the fuel tank. That is all I have come across so far. I am VERY happy with the quality of this ARF and I would bet these modifications are due to me using a 2 stroke. I have another one coming (this one was damaged enough in shipping for UPS to replace it but not so damaged it could not be fixed). I figured I would get a feel for the plane with this one so when I get the other one which will have a YS 63 and digital servos, I will be ready for it. I am also thinking of re-covering the new one. Good luck with yours.
Old 11-23-2003 | 10:24 PM
My Feedback: (24)
you need satio 100 umm and true turn spinner carbon gear both ends and carbon fiber push rods and good servos if you dont want any of that stuff at least replace the axles and push rods and the connectorsbut its best to go all out with the trics its a good plane
fix the gear plate
