Prop for Saito 150 and DP Ultimate >
Old 05-10-2002 | 11:08 AM
Default Prop for Saito 150 and DP Ultimate
I was considering an 16 x 8 prop for the 150. Would that be a good choice for hovering and recovery (when needed). I haven't received plane yet, so still have time for decisions.
Old 05-11-2002 | 05:48 AM
That is what I'm using on my 150 and it works very well.I'm using the apc prop but will try a wood one later.I am running it on 15% morgan full syntetic.Saito says not to use caster(I guess because of carbon build up).Funny my new magnum 91 manuel says to use some caster no matter what.
Old 05-11-2002 | 06:29 AM
A 16x8 APC is fine.
You might also like to try
an APC 17x8N
Old 05-11-2002 | 08:09 AM
Default 150
I'm getting good results from a 16-8 APC.
433rd
Old 05-11-2002 | 12:01 PM
JBrannon's Avatar
Most people use the APC 16-8 on this plane, I have the same setup 150 saito on DP Ultimate.
I use the APC 17-6. I like the longer blades with less pitch. Especially for slow flight. It harriers great and will torgue roll fast and easy.
Joe Brannon
Old 06-02-2002 | 01:40 AM
My Feedback: (7)
Hey guys.....is a Saito 150 enough power or should I go for a 180?? (DP Ultimate)
Old 06-02-2002 | 11:44 AM
If you already have the 150 stay with it. This is a very light plane and should come out to around 10 to 10 1/2 pounds. Use a 17x6 APC and go have fun. Vertical should be unlimited at that weight. If you want more try 30% heli fuel. Do not worry it will not hurt the engine because of the increase percentage of oil (23%). Satios love it!
Old 06-02-2002 | 01:07 PM
My Feedback: (7)
I don't already have a 150......should I buy the 180? I am trying to consider fuel consumption and vibration as well as power.
Thanks very much sport10!
Old 06-02-2002 | 01:56 PM
I am flying that plane with a 150 and YS 20/20. 16/8 seems to be the prop it likes. You will have to modify the firewall to get the muffler to work on the 150 or 180, or go with a Pitts style. Since you do not have the engine and if monetarily you are set get the 180.
-Rick
Old 06-02-2002 | 04:39 PM
I would get the 180 if you did not already have the 150. I still recommend the 17x6 apc over the 16x8 apc. Props with larger blades and less pitch seem to be better for 3D. They provide better braking and more thrust.
Old 06-02-2002 | 04:49 PM
My Feedback: (7)
Thanks guys.......180 it is. I appreciate the info!
Old 06-02-2002 | 10:23 PM
I read the review of modifying firewall for the Saito 150. I was considering getting the extension/muffler as shown on the Saitos website. It is flexible and am hoping it can snake around the firewall. Anyone tried that yet?
Old 06-02-2002 | 10:53 PM
I just used a hole saw and made the cut, then fabricated a new bottom using ply and fiberglass. It worked like a charm. I have not tried the extension but from what I have heard it does not work well keeps coming louse.
Old 06-04-2002 | 02:02 AM
If you want very unlimited power and use less fuel go with a OS 160 with a bison muffler.It will hover at 1/2 throttle and the 160 has excellent running quality.If you want a slightly used one(about a gallon of fuel)e-mail me.A guy in our club wants to sell his because the big planes hurt to much when they crash(the wallet that is)His new sukhoi and new 160 had a farming accident but the engine took no damage( 8th flight)
Old 06-04-2002 | 02:23 AM
My Feedback: (7)
Isn't it against the law to run a 2 stroke on an Ultimate?
Old 06-05-2002 | 03:53 AM
Trust me ... SPOCK is right on with engine and prop combination ...
I tend to think the 180 may be a tad much for the ultimate ... Spock's plane has unlimited vertical and will do every maneur in the book ... yes pun intended for the pilot's reading pleasure.
I know ... I have flown an ultimate and seen his fly on several outtings ... the plane likes a 150 w/16x8
now maybe a 180 with a 3 blade prop ... humm ...
http://communities.msn.com/DDawgPoun...to&PhotoID=100
