prop size for Kyosho cap.........
MN
Just need to know.....What size prop should I use for my Kyosho cap 232 .40 size......I have a gms .61 in it for the power...
i have the same plane with a thunder tiger .61 mounted in the frame. i am using an apc 12x6 which seems be do a good job. if i was going to do three d i would go for a 13x4 or 14x4 wide blade prop.
good luck
flashingred
good luck
flashingred
