Kangle Laser 200 arf info
FL
I have 3w fifty looking for a home, no time to build so I am wanting to arf it, motor is on the heavy side, this plane looks like good choice if the advertised weight is accurate. I need 14 to 17 Lbs max for this motor. Any info or opinions would be great. Thanks Brian
The laser 2000 from Kangke is a blast to fly. Mine is powered by a brison 3.2 and will do far more than I am capable of. Vertical is unlimited, it will hover at 1/2 throttle, great harriers and it lands like a *****cat. Run a search in this forum for previous postings and you will find some good tips.
