 Kyosho Gee Bee ARF (CG)need help!!! >
Old 01-28-2004 | 10:24 AM
Default Kyosho Gee Bee ARF (CG)need help!!!
What is the right CG for these planes need help ! will be flying this weekend. thanks tom
Old 01-28-2004 | 11:01 AM
Default RE: Kyosho Gee Bee ARF (CG)need help!!!
I found the factory cg (can't recall the distance at the moment) to be good. I've moved it back slightly and noticed the plane indicates a slight high speed stall coming around hard turns. Otherwise the factory setting fly's nose heavy (lots of elevevator inverted, and you can feel it on take off)
I'd leave it as is....
