Vector 300, OS 90 3D?
AB, CANADA
I have built my absolutely beautiful Vector 300 and installed the OS 90.
Is anyone else running this combo and if so what prop size and brand name is the best for this power plant for performing 3D maneuvers?
Is it capable of hovering and waterfalls with this engine?
Any help is greatly appreciated.
Thanx in advance.
Lean540
Thanx in advance.
Lean540
CA
Started out with a 91 FX with APC 13X8, now my preferred prop is APC 14X6. Out of sight vertical straight off the ground! A buddy is using a 91 four stroke and it flies great, although with less punch than the FX. Not much into 3D, but the 91 FX will hover it and do the high alpha stuff with the CG moved a bit back.
