Spacewalker CG question >
Old 06-03-2002 | 06:41 PM
B3X
Default Spacewalker CG question
Hello I have a Great Planes Spacewalker (wing span78 inches).
I do not have a manual for it.
- Where is the CG located ?
- On that type of plane do you mesure the CG from the top of the wing having the plane upside down ?
Thank you
Old 06-03-2002 | 11:08 PM
Default GP Spacewalker CG
This is the model that you balance upside down.
The manual says it should balance at 4-1/4" (108mm) back from the leading edge.
Had trouble with it floating upon landing but it appears that a 14-6 prop, along with good throttle management has solved this problem.
You will love this plane!
Old 06-03-2002 | 11:13 PM
B3X
Thank you very much this is going to help me a lot.
Old 06-05-2002 | 11:24 PM
You can download the entire manual for the GP spacewalker from their website. www.greatplanes.com
Good Luck,
Craig
Old 06-07-2002 | 03:59 AM
B3X
Thanks a lot ! that is very cool !
