 wing smoothing . .  .Kyosho Calmato ? >
Old 02-20-2004 | 07:53 AM
Default wing smoothing . . .Kyosho Calmato ?
I have just recieved my Kyosho Calmato ARF- while the package is top notch, on the bottom of the wing close to the servo mount there are a number of wrinkles/bubbles. The instructions say the covering material is "monochrome film." How do I fix this . .. is monochrome film the same as monocote ? Any ideas- heatgun or iron....?
Old 02-20-2004 | 09:53 AM
pettit's Avatar
My Feedback: (23)
Default RE: wing smoothing . . .Kyosho Calmato ?
It sounds like the spell checker they used after translating the manual didn't recognize "Monokote" but knew of the word "monochrome".
Try a heat gun sparingly. If it bubbles a little, then shrinks, you can continue.
Old 02-20-2004 | 10:07 AM
heatgun rather than iron ?
Old 02-20-2004 | 12:12 PM
Bax
Sorry, but the Kyosho Calmato isn't covered with MonoKote. We don't know what the material is, but it IS a heat-shrink material. Be careful with the heat gun, the material is a lower-heat material than MonoKote, so you can melt holes in it if you're not careful.
Old 02-20-2004 | 12:23 PM
Would a iron work better for this or heat gun ? I have to buy one on the way home from work---which would work better for this application ?
Old 02-20-2004 | 01:09 PM
do you have a hair blow dryer or an iron to press clothes with? If you do use them, wait till you have a real covering project to do so you can get any covering tools.
will
