Servo Wiring
NJ
I just purchased a used plane and the servo's and connector wire were removed. I got a flight pack with servos for each wing and the fuselage. I now realize that I needed to run connector wires inside the wing to each servo, whcih is mounted in the middle of each wing.
I wanted to know how to get the connector wire to the servo, which is about 16' from the opening in the underside of the wing ?
OH
Tie a nut to an end of a string, dental floss and drop through wing at one end, and pull it out the other. You may have to work the nut through the wing slightly lifting it and letting it go back down through the holes in the ribs. Daz...
BTW, when you tie the string around the nut, make sure you tie it really good, cause if that nut comes off in the wing, your going to have a time getting that nut out.
