 Big Stik .60 >
Big Stik .60
Big Stik .60
Old 02-28-2004 | 07:02 AM
Default Big Stik .60
Just wondering what type of pushrod assembly this ARF has. Cant find a good pic to see if it is tubes or not. If so are the tubes mounted? And any completion coments for this particular bird are welcome. Thanks Alot. Tom
Old 02-28-2004 | 07:48 AM
WCB
Default RE: Big Stik .60
Standard threaded metal push rods housed in plastic tubes that run through the formers. Standard setup. I have been flying mine since Oct. 2003. Easy to assemble. It come out very nose heavy with an Evo. .61 2stroke. Took several ounces of weight in the tail to balance. Flies great. No trim was needed at all. Using JR 537 standard BB servos and R700 rx and 1100mah battery. I recommend the plane. Good choice.
