"New" Lil Toni by Great Planes
#101
My Feedback: (-1)
OH
RE: "New" Lil Toni by Great Planes
N1EDM,
I have seen threads from several different sites including this one that the A-Frame types were never actualy used even though the instructions refer to that style being revised with the current non A-frame type. I believe others have actualy had grossly imbalance issues with the "TRU-TURN" style spinners, although this was not the case with mine. I was a lucky one that did not have a vibration due to a poor balanced spinner. I will be buying another Toni soon as mine went in sunday at over 100mph due to channel 22 issues at the local club I belong to. We have lost three planes late this year due to a complete lack of control while flying. My experiance was so bad that the throttle wouldn't even fluctuate when pulled all the way back! I just put in a brand new crystal and the complete radio unit was a new install with the plane as well. I fully charged over two nights on the slow charger and hit it with the field charger before going up. We have all decided to avoid 22 now at our field.
This plane will give you a great amount of joy flying and I cant wait to get another myself...I will be shure to check out the new spinner though...I probably wont luck out twice on that subject. I recomend checking it out before flying with it and having your plane shake apart when the prop/ engine unloads in the air.
Good luck with yours,
Jim
Hope yours lasts longer than two months....HE HE!!
Jim
#102
UT
Jim, I refer to the non A-brace type. I now notice a little wobble in my Tru-Turn spinner, I will probably switch to an Ultimate style spinner by spring time. The longer a spinner is, the more chance of wobble. By the way, are you or were you a P-3 jockey? Mike.
#103
I don't know if you were referring to Jim or myself, but I have 2500 hours in P-3 Orions as a Tube Rat (I flew SS1)
You can read a liittle more about me on that subject at www.qrz.com/n1edm.
How about you? Were you an Airdale too?
Bob
Bob
#104
My Feedback: (7)
Which muffler did everyone decide was best for the OS 91FX? Did anyone have a problem installing the horizontal stab? Mine has about a 1/4" gap or top and bottom which allows for the incidence to be off. Any tips or suggestions?
#105
UT
Bob, There was a time when I eat, sleep and drink L-188's. But, alas, those days are gone. Let's just talk about RC planes. Us "brown-shoes" can hold our own. Tell me more about your "Toni". Mike. "Airdale".......... now thats a word I have'nt heard in a long time.
#106
UT
GBI Guy, Yes , there is a gap at the horizontal. If you super glue it , don't take your eyes off of it till it's absoulutely dry. It will run when your not looking. Epoxy will work but you can only do one side at a time till it drys. Pitts muffler works best. I use a ST .90 on my Toni. Impressive too. Yes, you will lose quite a bit of the cowl. Seeya, MM.
#107
Bob,
I just received 8 pcs of 10-32 x 2-1/2" SHCS from Tru-Turn. They appear to be steel and silver colored. I had to drill out the Lil Toni spinner slightly using a #12 drill bit. The head dia. just fits perfectly inside the spinner nose, protruding out approx. .010". Would you like me to mail one of these to you (no charge)?
Roland
N6WQ
ex-W1UHH
Roland
N6WQ
ex-W1UHH
#108
TX
I was talking about cockpit cowling that you can by at the LHS. I've used it to outline the cut out portions in many cowls and it looks great. It gives it a finished look.
#109
LDJL,
Thanks for the offer on those screws but I just received some myself from McMaster-Carr (I broke down and got the SST ones). I went to mcmaster.com, and got part no. 92196A281 for under $10 for a pkg of 25 screws. That's more than I'll ever need too. Wish I'd waited a couple of more days... I would have split the cost of yours instead.
Thanks anyway for the offer. I appreciate it. I'll use your tip on drilling out the spinner though to accept the screw shank. The screw head fits fine in my spinner with no grinding. It looks like a thin wall though. I might just slightly grind down the OD of the screw instead, as an experiment.
I tried to put the spinner on my balancer, but the spinner is too long. I'll have to get some 1/8" and 3/16" steel rods to extend my balancer to check it.
Thanks for the idea, and the offer.
Bob
Bob
#110
My Feedback: (7)
I can slide a 3/32 peice of balsa through the opening for the horizontal and still fit the stab in with it. That seems like too much of a gap for superglue. What are you guys doing about the incedience of the tail. I would have thought that on a plane that goes over 100mph they would have taken a little better time fitting the tail peices.
#111
GBIguy,
After reading your post, I decided that I might check mine as well. I found the same thing...
I can't see any reason why someone should spend $250 for a plane and hfind that it has such a fundamental problem. It's such that you could introduce a degree or two of unwanted incidence into the horizontal stab.
Has anyone else had this situation? And if you did, how did you get around it? THe only thing that you have to glue to is the fiberglass sides, and if you're only gluing your horizontal stab to either the bottom or the top, that doesn't seem too secure to me...
I'm seriously considering sending mine back and finding another project...
Thanks for the heads-up.
Bob
Bob
#112
My horizontal stab had a gap of about 1/16" top and bottom. However there was sufficient contact area at both ends, top and bottom. I don't believe the stab will move. It does bother me to see daylight around it but I got over that already because the paint job is so darn outstanding, as is the majority of the kit. I should be airborn in approx. 2 weeks.
#113
Just had the first flight with my Little Toni.... Really nice flying airplane. I did though manage to put an Evolution NT 100 2s in the engine. Minor modifications to the pipe clearance was the only problem. I used a 14x8 prop and it did over load the engine... how ever the plane managed to fly flawless. Next weekend will be using a 13x6 prop... Hopefully this prop will have the plane performing at higher speeds. Over all, the plane is a great flier... landing gear is quite strong and will not bend on grass fields.... The only complain is regarding the wheel pants... Wish they had a better mounting system... One fell right off within 10 seconds of the first take off.
#114
I have stuffed a YS 110FZ into mine and will be using a 13-10 prop for starters. Using a 4-cycle makes for a clean engine installation. I expect to loose the wheel pants the first time I roll off of our narrow runway and run into the berm on the roadside. Too bad because they are so pretty (and functional).
#116
NC
Jeff Fudyna at GBI Hobbies in Atlantic Beach NC is building mine for me (I hate building them and I don't care how easy it is). It should be ready tomorrow. He is putting a .91 two stroke in it instead of a four. Should be scary fun......!
#117
CA
Do you guys think the os 1.40 or 1.60 is to much??
I think that would make an awsome combo for this plane.
let me know what the biggest you guys heard of going in this plane.
#118
The plane is rated for a .61 2S (recommends OS or ST), or a .91 OS 4S. I think an engine that big would be a waste... plus, I'm wondering if you'll have to add tail weight to offset the weight of the engine.
Besides, after seeing that huge gap in the tail where the stab is supposed to slide through, it threw cold water on the whole project. I shipped mine back today for a refund.
Just my $.02
Bob
Just my $.02
Bob
#119
The YS 110FZ fits inside the cowl nicely. Only the tip of the rocker cover protrudes. It nearly balanced at CG without weights. Only 1/2 oz. behind trailing edge made it perfect, and 1-oz in the left wingtip to balance laterally. This is likely the best choice for a 4-cycle engine without modification to strengthen the firewall. The Jett 90 with an exhaust extension is argueably the fastest 2-cycle that results in a clean installation.
#121
CA
Allright guys.
I ordered one from tower with an os 91fx.
I also bought a macs tuned pipe and header.
has anyone used this combo on there??
I haven't really heard anything about the tuned pipe from macs but I bought it anyway.
How I see it I wouldn't have to cut such a huge hole in the cowl.
and the tune pipe should give her a bit more oomph!
let me know if you guys have ever had any problems with the tuned pipe because I can always return it before I use it.
thanks
thanks
#122
My Feedback: (-1)
OH
Well...I used the Macs tuned pipe on my G-90 in the Little Toni. I bought the non quite version and was very pleased in the sound. It was not overly loud and had a very nice sound!! As for performance...I noticed some gain in rpm and it also helped the prop unload and sustain the rpm through level flight once it wound up. I think you'll be pleased with it!
Jim
Jim
#123
My Feedback: (33)
TN
Almost finished with mine. I have to mount my bettery/reciever and test fire and tune my Super Tigre. Here are some pics. Hope everyone likes what I did with my slim line. I am a very impatient person and this is all that the LHS had in stock.
#124
My Feedback: (37)
SC
I have an os 91 (vrdf) with pipe and pipe pressure. I flies fantastic! It also idles better with the pipe - aybe it scavenges better.
randy
randy
#125
Hi,
I wonder if someone have tried a OS 108. ? . I think it needs a big 2 stroke. What about a Rossi 105??
Any more pics about engine installations appreciated (prop /engine combo) . Thanks
