Bought SIG Kadet Senior
I just bought the Sig Kadet Senior for my trainer and many think it is a really good plane...
can i have some of your feedback on this plane.
Jon
Jon
RE: Bought SIG Kadet Senior
Put as much of the radio gear as you can as far forward as you can because it WILL come out tail heavy. I used a Super Tigre .51 on mine and still had to add a lot of lead to the inside front of the cowl.
Dont over power it with a .60 engine or more. A decent .40 is plenty of power for the Kadet Senior. Something like an OS .46LA would be plenty. The ST .51 I have on mine is overkill. My father put a Saito .56 on his and it flies great.
You may want to add some triangle stock along where the vertical fin meets the fuse. My fin came loose twice but that is probably due to the overpowered power dives I have done with it.
