CAP -X
JUST WANTED EVERY ONE TO LOOK CAREFULLY AT THERE CAP X WHEN ASSEMBLING.I FOUND THAT WHEN I INSTALLED MY ELEVATOR SERVOS
LAST NIGHT THE SERVO TRAY IN MY PLANE WERE BARELY TACK IN PLACE. ONE ACTUALLY FELL INTO THE PLANE.UPON FURTHER INSPECTION
I FOUND THAT BOTH SIDES NEEDED TO BE EPOXIED INTO PLACE.ALSO WHEN GLUEING THE STAB IN BE CAREFUL WHERE THE GLUE GOES.
IT IS A LITTLE TRICKY TO GET GLUED INTO PLACE.I HAD CA RUN HALF WAY DOWN THE FUSE ON THE OUTSIDE OF THE COVERING.A LITTLE DEBONDER
AND ALL WAS FINE. STILL A PRETTY GOOD LOOKING AIRPLANE AND A GREAT BY. I BELIEVE SOMEBODY WERE THESE ARE ASSEMBLED MESSED UP.
JUST BE SURE YOURS IS NOT LIKE MINE.
TX
This is not a problem that is unique to your Cap-X. This advice along with lots of other great information regarding the Cap-X can also be found in this thread:
http://www.rcuniverse.com/forum/Chip...1509239/tm.htm
Richard
Richard
