Edge 540
Hi Guys
I have YS 120 and Zenoah G-23 to install in Hangar 9 Edge 540.
In your opinion, witch will pull better?
Is this a good model for 3D and knife edge loop?
Thank you for help
Thank you for help
I have the H9 Edge running RCS 1.40 at 12 lbs RTF. It does very well.
I would say definitly go with the 1.20 for now... the G-23
would barely lift it's own self bolted to the Edge.
Now....for 3D I would recommend the ZdZ 40...less weight than the g-23 and TWICE the cc's...about 25 lbs thrust.
If I had to do it all over again....defintly would bolt the ZdZ 40 to it.
But for now...keep it LIGHT as possible...with the 1.20. You will be happy with it...The G-23 is only good for more wing area like UltraStick at 1200 sq inches and Trainer types....
I've never seen a G-23 do 3D bolted to anything....Thrust to weight is just not there.
Hope this helps!
High Flights.
CrazyHerb
Hope this helps!
High Flights.
CrazyHerb
