UCANDO3D Balance
[:-]Just finished my ucd 60 and put it on the balancer(Great Planes) and had done no pre balancing. I Placed the balancer at the reccomended balance point, which is 4 7/8" from leading edge of wing and immediately the vert. stab dropped to the table. I lifted it up and then the nose dropped. If I held it just right it would balance perfectly at the horizontal (on its own). My question is this, should I move the balance point back or will it be ok where it is? I know definately I don't want to try to fly it if it is tail heavy.
Thanks in advance for the info.
clemrick
clemrick
clemrick mine balanced out the same way it has that fine line witch is very touchy i flew it and it was just fine i also use the grat planes balancer, fly it ! i installed a os46fx with a tune pipe and it hovers just fine
My Feedback: (21)
I have been working my way back from 4 7/8", I am at around 5 1/2 now and for a complete amateur 3D'er, it makes things like inverted flight and hovering alot easier.
