 WM ZERO RETRACTS >
WM ZERO RETRACTS
WM ZERO RETRACTS
Old 05-26-2004 | 09:47 AM
Default WM ZERO RETRACTS
Does anyone no of a set of bolt in retracts that will replace the ones it came with?
LONNIE
Old 05-26-2004 | 11:30 AM
Richard L.'s Avatar
My Feedback: (24)
Default RE: WM ZERO RETRACTS
Which Zero are you referring to, the smaller 60 size one or the giant scale one?
Old 05-26-2004 | 04:25 PM
Its the gaint scale one
Old 05-26-2004 | 06:20 PM
My Feedback: (75)
I put a set of Robarts on mine. Needed to cut the struts to length. No big deal. I also needed to sure up the supports where they bolt in. They didn't provide very much supports so I added some blocks which is expected of a arf.
Old 05-26-2004 | 10:46 PM
What model robarts?what model struts? willthey fit rite in ? I just rebuilt the retract area in my wing and am trying not to have to open up it again.The retract mechanism works fine its those lousy legs that are so flimsy. ANY help with this problem would be greatly appreciated
lonnie
Old 05-28-2004 | 03:48 PM
p39
I've got a set of Century Jets for mine..... I'm installing them this weekend after beefing up the mounts. Contact CJ for the right ones....
Old 08-31-2004 | 02:07 PM
My Feedback: (24)
Call Spring Air...I can empathize with you. I've had negative experiences with CJ and Robart. You won't be sorry. Doug
