 Avistar Control Rods >
Old 06-14-2004 | 05:00 PM
Default Avistar Control Rods
Just a quick question, I am new to ARFs. Do the control rods for the rudder and elevator need to have any bends in them? Or are they just straight? I have a Extra Easy 2 and the rudder control rod bends to fit the fuselage. Thanks for your support.
T/A
Old 06-14-2004 | 05:36 PM
a65l's Avatar
My Feedback: (17)
Default RE: Avistar Control Rods
On my avistar the rods were straight. You have the metal pushrods inside sheaths, right?
Andy
Old 06-14-2004 | 08:41 PM
Yep the steel rods with the plastic sheaths. They are straight. Cool thanks for the info. Just should look at my instructions instead of looking at a totally different airframe huh. Appreciate it thanks.
T/A
Old 06-14-2004 | 09:01 PM
Transam, I usually have to put a SMALL bend just past where the pushrod exits the fuse to get every thing to line up and work smooth.
Ed M.
Old 06-14-2004 | 09:11 PM
Ok great I was kind of thinking about doing that. I would think after awhile the control rod if staight would chafe through the plastic. Thanks Ed.
Seth
Old 06-15-2004 | 08:06 AM
hookedonrc's Avatar
I had to put a little bend in both the ends that came into the servo tray area and on the external end as well. I ended up with a little binding on the rods. My making the small bends I fixed the problem. You want them to operate smoothly to keep the servo from having to work harder than necessary.
Old 06-15-2004 | 04:13 PM
Thanks Hooked.
