What is a #36 hole? It is in the GP UCD 46 manual
MN
What is a #36 hole? It is in the GP UCD 46 manual.
It says to drill #36 holes in the engine mount, and then you tap them with 6-32 threads.
What bit size did you guys use?
Thanks... --Dan
Thanks... --Dan
My Feedback: (17)
RE: What is a #36 hole? It is in the GP UCD 46 manual
ORIGINAL: KingSalomon
Thanks... --Dan
Thanks... --Dan
MN
yes but what size is it? is it metric? mine arent labeled with those numbers... i need an equivalent.
Comman drill bits are listed in fractional sizes. But, to fill in some of the gaps there are also numbered and letter sized drill bits. A #36 is 0.1065"
7/64 is a little larger and 3/32 is a little smaller.
Ed M.
Ed M.
You can get a good numbered drill set at Sears. You should use the correct drill number size drill when you drill a hole to tap threads into, otherwise the threads will not be cut at the right size........if the hole is to big the the screw /bolt could pull out.
Take a look here http://www.biscofl.com/numberdrill.htm
A #36 bit is only .48 cents.......might save your airplane.
You got correct replies, but I'm going to offer advice, based on my opinion.
Don't thread the mount. Drill it with big enough holes to drop the screws through. Put a locknut on the backside, one of those with the plastic insert, that won't unthread.
Just my opinion. I've done it both ways, and I've had threaded mounts let the bolts back out. I've also seen them crack at the threads. Never had either problem with drilled mounts with locknuts.
Good luck,
Dave Olson
Good luck,
Dave Olson
Scar, its easy then, just use a 7/64. Run the tap in until just the point protrudes. When you thread the bolt in you have a built in lock nut, then put your washer and locknut on as a safety.
Ed M.
Ed M.
ORIGINAL: bentgear
Ed M.
Ed M.
However, if you drill a hole with clearance for the threads, then the external locknut applies compressive stress along the hole, increasing the fatigue life.
I still recommend a clearance hole, and a locknut.
Dave Olson
MN
Thanks guys, I ended up getting a numbered bit/tap set. I can't but nuts on the underside of the mount because it is tapered so there is not a flat surface for it to sit on.
I want to get a better mount anyway, but I don't know which ones will work with my setup. I have a UCD 3D 46 / SAITO FA-80 combo.
---Dan
---Dan
---Dan
---Dan
I agree with Dave that a clearance hole and locknuts are easier to drill and less failure prone. On a tapered motor mount beam, I file (or mill) a flat for the nut and washer to sit parallel to the mounting flange surface...
My $.02
Cheers!
Jim
When I drill the nylon filled motor mounts I use a 3/32 drill and then use a 6-32 socket head machine screw to form the threads. It makes a super tight fit and I have not had any back out due to vibration.
Paul
Paul
