 Sweet spot >
Sweet spot
Sweet spot
Old 07-15-2004 | 12:59 AM
Default Sweet spot
Does anyone know the cg sweet spot with the twist with an O.S .70?
Old 07-15-2004 | 01:13 AM
My Feedback: (50)
Default RE: Sweet spot
The "sweet spot" should be given in the instruction manual that came with the plane. It shouldn't change from the recommended CG. You may however have to add some weight fore/aft to get it to balance. If you don't have the manual, maybe someone here will have the info, or you might try looking the manual up online.
Jim
Old 07-15-2004 | 12:26 PM
It does give a recomended cg but it is way too far foward. I was wondering if anyone had a better experience in a different spot!
