 Attaching Wing >
Attaching Wing
Attaching Wing
Old 07-26-2004 | 04:15 PM
Default Attaching Wing
I was wondering what is the preferred method of using the rubber bands to attach the main wing to an Avistar, and how many to use. Thanks.
T/A
Old 07-26-2004 | 04:22 PM
MinnFlyer's Avatar
Default RE: Attaching Wing
My usual setup is 5 front to back on each side, then a sixth one crossed front right to rear left and vice versa for a total of 12
Old 07-26-2004 | 04:27 PM
AcroJo's Avatar
I use 12, 5 on either side and 2 more crossed over to keep the other ones from slipping off. They say 2 rubber bands for every pound of plane and the Avistar is spec'd @ 5-1/2 lbs. although mine weighs in @ 4 lbs 4.6 oz.. Don't try to keep using them too long without replacement. When they get weak you will experience wing lift when elevator is applied. Quite disturbing when not expecting it or if in a bad attitude. Rubber bands are cheap. Good luck, Joe
Old 07-26-2004 | 04:35 PM
Thankyou for the help.
T/A
Old 07-27-2004 | 01:25 PM
quint-rcu's Avatar
My Feedback: (24)
If while you're at it you want some building practice, you might try replacing the rubber bands with a screw down setup. It will assure the same alignment at all times and be more secure.
quint
ID:	157951   Click image for larger version
ID:	157952   Click image for larger version
Old 07-27-2004 | 01:57 PM
AcroJo's Avatar
Quint, on the wing dowels, I notice just back from the leading edge, bottom side of wing, did you insert a piece of stock for the inner ends of the dowels? If not, what is that piece. I've been meaning to convert to dowels and screws, but did not look forward to pulling the covering and sheeting to accomodate solid blocking inside as the manufacturers do to support the dowels. Thanks, Joe
Old 07-30-2004 | 02:34 PM
quint-rcu's Avatar
My Feedback: (24)
Good eyes! Yes that's a piece of 1/4 ply I inserted to catch the rear end of the dowels. It was only because I didn't have enough scrap dowel to reach all the way back to the main spar. It is not needed if you make the dowels longer (into the main spar ply doubler used to join the wing halves).
It's not hard and done with some scrap pieces. Mount the wing and drill through the wing and the ply attachment piece you epoxied at the rear with a bit smaller than 1/4". Remove the wing and drill it out to let the 1/4x20 nylon hold down bolts slip through and then tap the mounting plate. Note that the mounting plate is from 1/4" ply and the center has been cut away to let the aileron linkage work. A little bit of fast CA at all the drilled out openings (and the threads too) will strengthen all. Just run the tap through again after the CA sets up to clean the threads.
quint
