SEAFULL SPACEWALKER 2
My Feedback: (9)
MI
HI JUST BOUGHT AND FLEW A SEAGULL SPACEWALKER IT FLEW LIKE COWDUNG, I HAVE ADDEDDED 8 OZS TO THE TAIL FOR THE PROPER CG I HOPE THIS HELPS HAS ANYBODY ELSE HAD THIS PROBLEM THE PLANE WAS IN CONSTANT CRASH MODE I GUESS I SHOULD HAVE BALANCED IT BETTER BUT IT WAS NOSE HEAVY WHEN I FLEW IT THE FIRST I WAS TAUGHT AS LONG AS IT IS NOSE DOWN YOU CAN FLY IT I HOPE IT IS THAT SIMPLE THE PLANE ALSO NEEDS A LOT OF UP ELEVATOR TRIM TO FLY LEVEL ANY HELP WILL BE APPRECIATED THANKS ALOT CHRIS HEYSTEK
OH
Did you balance it on the CG? I don't have the cowl on mine yet (waiting until the engine is fully broken-in), but I did have to move the battery closer to the servos.
Turn off the all caps, please.
-Jeff
-Jeff
My Feedback: (9)
MI
i used a cg balancer, at 75 mm which is 7.5 cm behind the leading edge and it took about eight ounces to balance it yes the cowl was on to hope to fly it today thanks chris
My Feedback: (9)
MI
mornin no not sure on the weight but it wqas a whole strip of prather lead mds 46, plane flew much better way over powered flys at about 1 /4 power just fine chris
