 Changing engine mount on Funtana 40 >
Old 08-14-2004 | 11:35 PM
Default Changing engine mount on Funtana 40
I want to mount a Magnum 80 4 stroke on a 40 size Funtana. Any suggestions on the easiest way to do this? The engine will not fit into the engine mount provided and I don't really want to move the blind nuts if I don't have to.
Thanks.
Old 08-15-2004 | 12:47 AM
Default RE: Changing engine mount on Funtana 40
(Deleted because I put info on the wrong mount)
Ed M.
Old 08-15-2004 | 05:58 AM
Cheech's Avatar
My Feedback: (19)
I mounted the Saito 100 on mine using the mount they supply. I DID have to move the blind nuts, spacing them out a bit.
-Cheech
Old 08-15-2004 | 07:56 AM
Cheech, you are right. Thinking of the wrong mount when I typed in the above. Guess I should hav ewaited till this morning and I had my coffee.
Ed M.
Old 08-17-2004 | 09:59 AM
Cheech, how much trouble was it to move the blind nuts in this plane? I think the top two blind nuts are blocked by a support.
Old 08-17-2004 | 01:02 PM
Cheech's Avatar
My Feedback: (19)
ORIGINAL: Marino420TD
It was a pain, moving blind nuts always is. The top ones are as high as they can go and the engine is still 1/8 to 1/4" low. But it's hardly noticable and the plane flies good.
