 4star.60 arf >
4star.60 arf
4star.60 arf
Old 08-15-2004 | 12:19 PM
Always flying's Avatar
My Feedback: (22)
Default 4star.60 arf
I just finnished the arf 4star60, the only concern i have is that the supplied wing/allieron line up tool(shaped peice of bala) lines the allierons so they looked drooped when you look down the botttom of the wing.... is this right or should i just a just them to be even with the wing, i haven't taken the plane up yet, just want to know forsure if i should go with what sig has supplied for me (the line up tool) or just line up the allierons evenly with the wing? thanks manny.
Old 08-15-2004 | 01:35 PM
Oregon Craig's Avatar
Default RE: 4star.60 arf
You are speaking of the APG or Aileron Positioning Guide.
I used it on my .40 sized kit, and it worked, if that means anything to you.
Old 08-15-2004 | 02:35 PM
TimC's Avatar
I used it also and I think I remember they were both down a bit. If you use two channels for flaperons you can adjust it where it flies best. I've tried them down a bit and straight and there is not much difference. With them down, you might have to trim a little up elevator. It will fly fine either way.
