New 81" GP Super Chipmunk
#927
RE: New 81" GP Super Chipmunk
ORIGINAL: RCHubbub
Wow, after spending all of this time reading through 37 pages, this thread just came to a screeching halt. What happened?
I went through some very hard times last Spring and Summer including loosing my brother. I'm trying to work up the energy to put it together. So I went out and bought a SIG Sun Dancer 40 and the GP Giant Aeromaster. I'm a glutton for punishment. I hope to have all three in flying condition for Spring. We will see.
John
#928
IA
I have 27 flights on mine. It flies great with the OS 120 Surpass. My only complaint is the rather weak landing gear. Unless you really grease it in the gear winds up bending. It is easy to straighten but it is kind of annoying. If anyone has flown with the Robart struts I would like to know how well they are holding up.
#929
I have about the same amount of flights on mine with a US41 gaser in the nose. Have not bent the gear yet. I try to do a three point landing in the grass to avoid bending the gear. Just bring it over the field with flaps down to about 3-5 inches off the grass and bring the nose up slowly to sall the plane in a three point atitude and let it settle onto the runway just as it stalls.
Give it a try.
Gary
Give it a try.
Gary
#930
Got my Chipmunk right after Christmas. Downloaded the manual the week before and went to Great Planes website for updates, noticed the new double pins on the center wing area with steel inserts. Really impressed with the way it looks, wasn't really happy with all the ironing I had to do on the wings to smooth them out, but they came out ok.
Wings and tail feathers complete. Have a CRRC GF26I gasser to mount. Engine is only 3 3/4" from mounts to thrust washer, fabricated a 2" aluminum mount to go between the firewall and standoffs that came with the engine to give me the 6 3/8" spacing as per the manual.
I have not mounted the engine yet as I have questions on the mount location. It is up and to the right facing the nose. Can someone tell me if I have to mount the engine off to the right, I know the vertical must be where it is to fit the cowl, but can I move the center of the engine to center of the firewall. I know enough about thrust angles to get into trouble. Can someone help me out?
Ed
Ed
#931
edwal, Make sure you read through the intire thread. Also with using a gas engine please forgo the CA hinges on the tail and use either pinned hinges or Robart hinge points. I used the later and placed them so they would go into the ribs for better glue purchase. As far as the engine mount goes, use the cross hatch drawn on the firewall to center up ytour mount. You may have to extend the lines some. All engines crank center should be in the same place. The right thrust is built intro the firewall already.
Gary
Gary
#932
gary9648 Ive been flying mine for quite a while now with the CA hinges with no problems,,as long as you seal the gap at he bottom so air doesnt flow thru. I running a G-38 on mine and lovin" every minute of it . I also am using the robart struts. Believe me its worth every penny,,,Because they absorb a lot of shock. TAZZZZ
#933
Thanks Gary and tazzz,
I just wanted some guidence, I have read all 38 pages and taken notes, I have already installed the CA hinges, and I will seal the gaps, I will keep an eye on them on the preflights.
I think the GF26I will fit in the cowl ok with just minor trimming for the spark plug and the front of the head. Would you recommend a servo for the choke? I can put a manual one that will come out the bottom of the cowl. Which would be best?
I plan on mounting the ignition module behind the engine. The mount I fab'd is 3" square on the front with 2" legs. I put a 1/4" piece of ply inside for the blind nuts for the engine. That will allow me to mount the module on the ply between the firewall and the engine, plus room for the 2500mAh battery if needed for nose weight.
I will post pictures once I get the engine mounted and ask for recommendations and suggestions. This is my first gas engine and my largest plane to date. I have 8 so I am not completely green, but close, I have been out of RC for over 20 years before coming back last July. I really forgot just how much I loved this.
Thanks for all suggestions and recommendations.
#934
Personally I wuold leave the choke at manual,because its really not used that much,,and its just one more servo you dont have to be concerned about. You can devise any number of ways to access the choke, its so much easier,, most engines ,the choke is extremely easy to get at,,,,,But like I said just my opinion. Every thing your doing seems to be fine ,,let us know how you make out. TAZZZZ[sm=thumbs_up.gif]
#935
MN
This plane looks great.....
Price seems to have come down quite a bit!
I noticed that mose people with glow engines (even 4-strokes) are mounting horizontal?
why not mount inverted and save the cutting on the side and put it out the bottom!..
26cc gasser goes good with this one?
Justin
Justin
#936
NV
I just got one of these on order from my LHS. I am thinking maybe a Saito gasser (built on a 220) 36cc all up weight to be about 61oz. I am also considering the OS FS-200 which is around 35oz. I am thinking I would like to go gas on this bird. Any thoughts on either of the engines???
#937
MN
Both are too new to have any flight experience......
I believe both would do well.....
The NItro os would require some balast....the saito gasser would not....
#938
CA
A chipmunk is a great canidate for smoke especially the 81" GP version. If you guys are lookin for a super light compact smoke pump check out the harris brushless programable competition pump it only wieghs 2.2 oz and does not require an aux battery,other systems are 8+oz. you can find them at harrismodelproducts.com. they are so light and small you wont even feel the wieght. rc3dflyr
#939
MN
Looks nice but the price always goes up when something is lighter than the rest
I know what you mean when you start adding up the weights......
I already have a pump for smoke, and I not sure if I will put it on my giant cap or not.....
I wouldn't have any issues placing the pump in this plane either, even though it is a heavy/normal one....
Justin
Justin
#940
My Feedback: (21)
KY
I have a 2-stroke 35cc gasser in my plane (yep - still haven't flown it) but I'm expecting ballastic performance. My guess is that the saito will be an awesome motor for this plane.
#941
My Feedback: (121)
MI
Well, I just got mine from Tower... now for the engine. I read the entire thread and I need to purchase one of the following engines for this plane, Saito 180, YS 140, OS 160, Moki 210 or a gasser... lots of choices and the Toledo show is a month away to help make the choice easy...
#942
I just bought one and i can't wait to get it in the air. I have ordered a 40cc BCMA gasser for it. Plenty of power and hopefully won't need any lead up front[8D]. I have always felt that it is better to have more engine that dead weight. And at a 14 pound flying weight the 40 cc will be a great match.
#944
My Feedback: (14)
Plane Jim,
I had posted sorry to hear about your loss and someone else posted they wanted to know what happened but they were deleted.
What happened to your plane?
Someone else had posted great planes was loosing the licensing rights and selling them cheap. That post was also deleted.
Checked the website, the Chipmunk had been discontinued.
#945
My Feedback: (14)
ORIGINAL: sevans16
#948
MN
ORIGINAL: Skypilot_one
The Saito will rip the fuselage apart. Of those two engines I'd get the OS200.
I had heard that the 220 glow would most likely rip apart a 73" qq Yak 54... but I wasn't sure about the gasser....
I believe that the gas saito engine will run quite a bit smoother than the glow.... especially at the lower end of rpms....
I have a ZDZ40F3A gas and it is unreal how smooth that engine runs...... but then again, it isn't a 4-stroke...
If I had the engine, I could tell fore sure, but I would give it a try....
But then again
it's JMHO!
Justin
#949
My Feedback: (14)
The OS 200 is reported to be very, very smooth. The Saito is a shaker. I don't see how adding spark would change that. But hey, buy one and let us know how it is. I would love a gas 4s. Does the Saito use a roller bearing con rod or is it plain bushings?
#950
My Feedback: (13)
MI
Can't believe it, Tower has discontinued this plane. I just got mine a couple weeks ago from Tower at $250 which is a great deal in my opnion. Must have been one of the last ones. Putting a Fuji 43E in it. Now worried about spare parts.
