 Powerline Hobbies .46 Edge >
Old 10-24-2004 | 08:17 AM
Default Powerline Hobbies .46 Edge
Can anyone who has built this plane help me with balancing. I have the radio installed and the engine temporarily installed at the end of the engine mount and I still can't get it to balance. It's tail heavy. I don't want to add any additional weight to the nose. I have an OS .70 Surpass 4-stroke in it at this time. I'm trying to balance it at the main wing spar. Any suggestions?
Jim
Old 10-26-2004 | 04:22 PM
Default RE: Powerline Hobbies .46 Edge
I have built and flown the plane and also deal the product line.
My plane is currently set up as follows:
Saito 72 out almost to the end of a Dave Brown mount.
Futaba 3004 servos 2 in the tail, 1 in each wing and 1 in the throttle servo position.
The supplied fuel tank is in its stock position
1200mah 4.8v Ni-Cad is under the fuel tank.....
GWS RD-8 Receiver mounted in front of the throttle servo, right behind the tank......
It balances perfectly as I have it setup......hope this helps!!!
Let me know if you have any other questions.
Bill
Old 03-14-2005 | 08:33 PM
How far back from the leading edge did you balance te plane?
Jim
