Air Wild Giles 300
My Feedback: (8)
VA
RE: Air Wild Giles 300
Well its been about 6 months since I got the giles and finally got to maiden it today. What a great flying plane, it flys lighter than anything ive flown even the funtana 90. The BME 110 has tons of power with a menz 27-10. Just a little mixing and it will be perfect. Strange thing though it flys perfect in KE going from right to left, however it pulls to the belly in KE going left to right also has a little of roll coupling in this direction (very small amount). All in all it flys very very nicely. I had so much fun today I ran it out of gas on the second flight (around 30 seconds after landing) I hope there are more people that get to enjoy this plane as I have today.
My Feedback: (8)
VA
Hey dick I installed a pull pull set up on the elevator and rudder and mounted everything as far forward as humanly possible. Ill post some pics sometime tonight.
set up is: bme 110 with stock exhaust, menz 27-10 (no spinner)
hitech servos for ail(5645) and rudder (5735?)
32oz tank
jr 8611 for elevators
slimline showtime smoke pump with a 24oz tank
(2) 2200mah nimh for servos 1100mah for rec. and throttle
power bus pro
1600mah for ign.
I dont know what the weight is however after flying it it doesnt matter. Icould only guess that it is about 25lbs. The balance was right in the middle if what they say in the manuel(9.5"plus or minus a little bit)
32oz tank
power bus pro
1600mah for ign.
