 Modeltech Joss Stick >
Old 11-20-2004 | 01:26 AM
JD380's Avatar
My Feedback: (133)
Default Modeltech Joss Stick
Anyone of ya'll have any experience with one? Just bought one from another member, was not finished out and is in great shape. I was just wondering what some might of done to one while assembling that would make it better. I'm already thinking of using individual servos for the ailerons since it's a pretty good-size plane.. Previous owner replaced the supplied taildragger gear with a much better setup. Will be mounting a Super Tigre 90 on it. Not too thrilled on how the fuel tank mounts, will probably address that too.
Thanks in advance for any thoughts.
Old 11-20-2004 | 02:40 PM
Ed_Moorman's Avatar
Default RE: Modeltech Joss Stick
Good flying plane. I had one for years to fly in larger engines and mine had several on it. I liked the .91's best. The .61s were low on power and the 1.08s were too heavy.
You really do need 2 aileron servos. Mine had 4 servos in the wings with flaps and an Ultra Stick set-up program in my 8103 for crow.
It also needs 3 degrees ( about 2-2 1/2 inches)anhedral on each side to be able to fly knife edge without rolling out. I am attaching some photos. The one with it inverted in a cradle shows that it looks like a low wing plane with dihedral when it is upside down. I have flown all three, stock dihedral, flat wing and anhedral.
Stock dihedral-it's just a big old trainer type plane, poor outside tracking (wants to roll out of outside loops/maneuvers), rolls out in knife edge and in long turns.
Flat wing-flies better, but still rolls out in knife edge. Better outside tracking.
Anhedral-flies like a low wing plane. Good outside tracking, holds knife edge without aileron. Holds bank. Seems to land a little slower, but this may be the false perception that it is packing air under the wing for better ground effect.
ID:	194733   Click image for larger version
ID:	194734   Click image for larger version
