Source for Somethin Extra ARF covering >
Old 08-21-2002 | 03:03 PM
Jaco's Avatar
Default Source for Somethin Extra ARF covering
I have a SIG SE and am looking for a roll of Oracover #54 Violet covering that matches. I believe its the same stuff as Ultracote but I cannot find the same color.
Old 08-22-2002 | 12:16 AM
If I'm not mistaken, it's the same covering that's used on the Sig Extra 300XS ARF, and that is the Ultracote Smoke Purple.
Lynn
Old 08-22-2002 | 12:21 AM
Default SE UltraCote (smoked purple)
Hey Jaco,
How did the maiden flight go? How much purple do you need, I have a little extra if you are talking about a hatch cover for moving the battery back in the tail section.
SearchMan
Old 08-22-2002 | 01:07 AM
Ultracoat is the same thing as Oracover, Horizon Hobby has it. Just give them the #.
Vince
Old 08-22-2002 | 01:15 AM
Jaco's Avatar
Default Re: SE UltraCote (smoked purple)
Originally posted by SearchMan
Hey Jaco,
SearchMan
Hi Jim,
The maiden flight went great. Sunday was a perfect day with no wind. I couldn't find a 13X6 prop locally so I went with a 14X5 on the Saito .72. Seemed to have tons of thrust. I could take off in about 15 feet and point it straight up. Did some hovering, loops and rolls on low rates. This weekend I hope to move the CG back some and try it on high rates w/mixing.
I might take you up on the covering if the smoke purple doesn't match. I want to move the RX pack back to the tail like yours. Maybe I'll see ya at the field on Saturday. Thanks for your help!
Mike
Old 08-22-2002 | 01:21 PM
Hey Mike,
I plan on flying Saturday morning (if it isn't raining) and I'll bring some "smoke purple" Ultracote with me. Also, I had to replace my rx pack so I am leaving the covering off the battery access so I can add a little weight in the tail so I can do the inverted flat spin thing again.
Jim
