Knife edge and the H9 Aresti
GA
From reading some of the posts here it is my understanding that the H9 Aresti isn't that great in knife edge flight and that the rudder in general is a bit weak. I am about to start construction on mine and would appreciate advice on enlarging the rudder.
About how much should it be enlarged ? Also, is there much coupling in knife edge with the rudder and if so in what respect ? Would it be best to change the shape of the rudder a bit when enlarging it, ie., by increasing the cord at the bottom or top of the rudder ?
I am also considering taking out a bit of the dihedral. Opinions ?
Dave
Dave
The Aresti does not do that great a KE but its not lousy either. Take your CG back a bit, mine was with a Saito 72 and I had about 2 oz of lead in the tail and I could have taken the CG further back without the plane being twitchy. My WM Super Chipmunk does a much better KE than the Aresti. There is no need to have a larger rudder.
