U-Can-Do 46
AZ
I just purchased this plane and was wondering if all the problems with the wings and tail feathers failing have faded away or are there still problems with this? I haven't seen any recent post with these problems. All the threads I found with the search function talking about these problems were about a year old. I plan on upgraded the push rods and adding tail braces to help with this. Also, is there a problem with the fuel tank location? Do I need to adjust it for better alignment with the carb on my Saito?
Jeff
Jeff
ND
i don't think there really ever was a true wing problem, most of what happened usually sounded like it was high speed flutter, whether or not it was ever directly stated. I DID loose my first .46 due to a sort of wing failure, the hold down block for the wing came unglued, inflight...
as far as the tail, it is a weak design near the fuselage. not something that will affect flight when it fails but still annoying. (I've flown my .46 with the horizontal stab basically free floating!!)
My Feedback: (17)
ID
You don't need to relocate the fuel tank. Stock position is fine. I run a Saito 82 in mine without any problems. The fuel tank position was a problem on the 60 size not the 46.Thanks,
Barry
