 NexStar Select Covering >
Old 12-30-2004 | 07:55 PM
Default NexStar Select Covering
I recently purchased the NexStar Select after flying a 3 channel electric for 2 months.
Questions: 1. Is it normal for the covering on a new Nexstar Select to be wrinkled on the wings and fuselage? 2. Will this change the flight characteristics of the plane (alierons have big bubble in covering)? 3. This is my first gas trainer and I want to spend time on the sim before going to a field, will storing this plane assembled in a shed with temps ranging from 10c to 70c harm it while I get in sim time (2 to 3 months storage in shed)? 4. Should I return the plane before assembly because of the covering?
Old 12-30-2004 | 09:02 PM
ICE_MAN's Avatar
Default RE: NexStar Select Covering
It's perfectly OK to have some wrinkles in the covering.. Just take a heat gun (Hairdryer works) and shrink them out..
Old 12-30-2004 | 09:08 PM
Thanks. Got any recommendations on storing a plane in a none heated or cooled area.
Old 12-30-2004 | 09:23 PM
cstevec's Avatar
CSHANNON, the cold won't hurt your planes but you may get a few more wrinkles in them. I store my planes in the garage (detached) and there are usually 3 or 4 in my trailer all year long. I have never had a problem with it. One thing I have noticed though. The planes that are covered with Monokote tend to wrinkle in the winter time but the wrinkles come back out when the weather warms up. If I shrink 'em tight in the winter, when summer comes the covering gets tighter and the surfaces warp. I learned that the hard way so I just live with the wrinkles now. Ultracote is not as bad.
