Fuel Tank Problem
Hi,
I went out to fly my planes yesterday and had nothing but problems, one that I hope someone can hlp me with as I don't know what is wrong.
I have built a Black Horse Twister (Very nice to build by the way, everything went in nice and easy), but I have having a problem with the fuel tank. I doesn't look like it's suppling any fuel to the engine. I have checked the tank, no leaks, the tubes are correct and going to the carb and exhaust correctly. When you blown into the exhasut tube fuel comes out of teh carb tube.
This engine does have a tuned pipe and the tubing is very long to get to the nipple on the tuned pipe.
Can anyone suggest anything?
Thank you
Thank you
The problem is that the engine will not start. I suppect that fuel is not getting to the engine.
I have checked the glow plug, that the engine is turning.
I'm really stuck, can not think of what could be causing these problems.
My Feedback: (551)
Sounds like foreign material in the carburator, or a leaking filler valve. Pull the needle valve all the way out, leave the fuel line connected and blow through the vent line. Fuel should come out of the needle housing, but not through the filler valve. Then put the needle valve back in, but only a couple of turns, and do the same again to force fuel through the spray bar. Fuel should flow into the carburator throat. Turn the needle valve back in to the normal setting and take the glow plug out. Now spin the engine with the starter for 5 seconds to eject the excess fuel that ran into the carb while you were doing this. Put the plug back in and the engine will start.
Jim
Jim
just to cover all the bases you might check to see if the clunk is setting up aginst the rear wall(too long) i say this because fuel will still flow with pressure (from you blowing) but not suction. just an idea.
Gary
Gary
There is a very good chance that the lo speed needle is closed too far. Open it up a full turn and see if it gets fuel then. You'll have to retune but at least you'll know it's getting fuel.
My Feedback: (16)
GA
I would try the following.
1) remove the glow plug, put your finger over the exhaust and use your starter to spin the engine. Does fuel go to the carb and is the carb wet or fuel blowing out the plug hole? If yes, you have enough fuel.
2) Test the glow plug to make sure that it does glow. If yes, then you have a good igniter and plug.
3) Spin the engine with your finger off the exhaust and the plug out to dry the excess fuel. Install the glow plug, Open the carb barrel 1/4 the way and spin the engine with the starter. If fuel does not go to the carb, put your finger back over the exhaust.
4) Doing the above, will start the engine. If it doesn't, it is either flooded or ??????
