 Right Thrust ?? >
Right Thrust ??
Right Thrust ??
Old 03-08-2005 | 06:01 PM
Default Right Thrust ??
I"m building {putting together} a Great Planes 60 Big Stick A R F . The fire-wall has no right thrust, Is this O.K.??
This is my first ARF. I hop they used enough glue!! ??
Matt
Old 03-08-2005 | 06:48 PM
DVI
Default RE: Right Thrust ??
Hi Matt
I would put it togeather as intended. After flying you find your self having to hold right rudder during climb out to maintain a stright line then I would shim the engine a degree or two to the right by adding washers under the engine mount.
And I would also use trangle stock and epoxy them into place around the back side of the fire wall if it does not already have them.
If it does already have trangle stock I think that I would still epoxy the back side of the fire wall just for good measure!
Old 03-08-2005 | 08:09 PM
Thanx DVI
The epoxy is curing now
I'm making it a bottom winger and powering it with a s t 75.
Do you have any more hints.
Matt
