smoke?
CT
Hey guys how do you think a kange cap 232 with smoke would be the plane is powered by a ys 140dz engine. I also have a gp patty with bme 50 that already has a smoke muffler. I would like to put smoke in one of these planes just to use for show now and then. What do you think?
Rob
Rob
My Feedback: (32)
ORIGINAL: rob6894
Rob
Rob
I have the same Cap that is getting a Roto35Vi and was pondering the same thing. I did go with smoke on my CG Sukhoi with a Zenoah G26 converted to Electronic Ignition and it works well. I have never done smoke on larger 4 strokes but I can say this on gas it's pretty good. The Zenoah uses an Abell muffler. I cannot find it at this point, but there is a diagram out there that uses the pressure system from the YS engines to pressurize the smoke tank and a Dubro servo operated smoke valve
Here's a video of my Skybolt with a YS 91AC smokin up a storm.
http://204.96.183.34/Skybolt/Videos/...t_high_res.wmv
More smoke info here:
http://www.rcuniverse.com/magazine/a...article_id=455
MO
Hey Minnflyer,
Great Smoke!!![sm=thumbup.gif]
Question? Are you using a preheater of any sort and where and how are you "spraying" the smoke oil. I am presently installing the new TME SmartSmoker pump system on a Magnum .91 FS pulling a Global Ultimate Bipe and was thinking of making a preheater" if necessary".
Some pics or just install tips would be great. Thanks.
Twindaddy, I don't preheat. I tapped the muffler header about 3/8" aft of the head.
This link shows a diagram of the system I use:
