 kangke laser2000 what size engine? >
Old 03-15-2005 | 06:25 PM
My Feedback: (36)
Default kangke laser2000 what size engine?
what size engine would u recommend for a kange laser 2000? I have a DA 50 do u think it would be strong enough for 3-D on this plane or would a ZDZ 60 be better? [sm=punching.gif]
Old 03-16-2005 | 07:17 PM
Default RE: kangke laser2000 what size engine?
I KNOW SOME ONE THAT HAS THAT PLANE WITH A BRISON 3.2 FLYS GREAT!
Old 03-17-2005 | 05:30 AM
I had the Laser 2000 with a G-62 in it. It simply amazed some of the guru's at our field by it's performance. I can only imagine how nice one will fly with a DA-50............
Old 03-17-2005 | 02:17 PM
Texastbird's Avatar
My buddy's has the ZDZ 60, and it's real nice. The DA50 should work well, just keep track of the weight of the plane. Maybe consider CF gear.
Old 03-17-2005 | 03:39 PM
TD1
Tail Heavy
Don't use the ZDZ 60, too much weight. I have a Laser 2000 with the DA 50 and it has plenty of power for the laser, it will hover at around 50% power with a strong pull out from hover. By the way I am using all the stock gear that comes with the plane and total weight is 16,5 Lbs.
