 Wing adjustments? >
Wing adjustments?
Wing adjustments?
Old 03-30-2005 | 05:12 PM
Default Wing adjustments?
On the top wing of my GP trainer forty .. when i have the plane laying flat on the floor how important is it that
the trailing edge of the plane be 1/32 lower than the leading edge? what if it is more or less ?
Old 03-31-2005 | 10:48 AM
daveopam's Avatar
My Feedback: (9)
Default RE: Wing adjustments?
If it's close it will be fine. The only thing is the ELEV trim may change with the throttle setting. It's not a big deal. I hope you have some one to teach you on a buddy box. If not at least get some one to trim it out for you.
David
Old 03-31-2005 | 11:51 AM
MinnFlyer's Avatar
I think yours is more a question of Angle Of Attack (AOA) rather than Incidence. As long as the wing is close to level, you'll be fine.
I won't get into the sordid details, but some say the wing should sit with a slight negative AOA. Your manual (And I) believe it should sit with a slight Positive AOA.
Bottom line... Don't lose any sleep over it.
