 control horns - help!!! >
Old 03-30-2005 | 09:35 PM
Default control horns - help!!!
I'm new at this, and can't seem to line up the holes when installing the control horns. Anyone have any tricks out there??
Old 03-31-2005 | 08:33 AM
MinnFlyer's Avatar
Default RE: control horns - help!!!
Hold your drill straight
But seriously, bevery conscious of the angle your drill is on, and keep it the same for the second hole. After the drill is through, wiggle it around a little to enlarge the hole. After all, it's the clamping of the two control horn plates that hold it in place, not the tightness of the holes.
Also, when you screw it in place, don't tighten one and then try to start the other - Get the first one started, then start the other and then tighten them together. Because when the plate is away from the surface, you have more leverage to move the mismatched screw hole.
Old 03-31-2005 | 08:37 AM
Those things drive me crazy too. If you sharpen the screws on the end with a file they will start alot easier too.
Bob
Old 03-31-2005 | 08:39 AM
MinnFlyer's Avatar
This question is posted in the beginner's forum as well.
It is against RCU Policy to post the same question in more than one forum, so I am going to lock this one.
