Seagull Space Walker II throttle pushrod
Do you guys think I should replace the throttle pushrod? Not real crasy about the metal on metal contact between the pushrod and the throttle arm. I have flown it wothout problems, but wondering if I should replace it[sm=confused.gif]
That is one of those things that is "six, of one - half dozen of the other"
As long as it works, I wouldn't fix it. Now if you were getting servo jitters from it, then I would change it.
On mine, I used what Seagull supplied with no problem
