Great Planes PT- 17 Stearman ARF
#426
My Feedback: (42)
RE: Great Planes PT- 17 Stearman ARF
Still waiting for ups to pickup plane, now I have to pay for half the shipping cost, I called everyday for 5 days to finally get the label but find out from ups that I have to cover half the cost. Meanwhile no refund to my credit card, just think if I had a another plane shipped I could be paying for 2 planes going back.
#427
My Feedback: (22)
Hey guys,
I'm just finishing up my GP Stearman with a Saito 125. While reading the Saito instruction manual I noticed it recommends that the tank center should be about 5mm below the carb center. But with the inverted mount, as per the GP Stearman instructions, my carb will be below my stopper. Is that going to be a problem? Have you guys been lowering the tank? I think I can lower it an inch without too much trouble.
#429
#430
SC
Pilotfighter:
I did not lower the tank and have had no problems. I also have a Saito 125. You will enjoy that set up! Your plane looks great! good luck!
Brad
Brad
#431
My Feedback: (42)
Well I finally got my credit for the return of the stearman after paying half the shipping now they have kept another 10 bucks off the oringianl invoice, I am out 25. bucks and nothing to show for it, the girl at tower says she can see the difference but does not know why they didnt refund the entire price, unbeleivable.
#435
I think I had one of the better ones. It took a couple of hours to straighten out. But, at least I didn't have to replace any. The ailerons were the worst.
#436
ORIGINAL: LTJeeper
#438
At that price it's worth it. It's really a nice plane and Tower was good about replacing any parts needed. I maidened mine last wkend with the DLE 20 for power, a real cruiser if you want but plenty of power for loops etc. Where do you see it for 359?
#439
ORIGINAL: raptureboy
#441
ORIGINAL: MsgtRob
Just get it!!
The wrinkles are workable....You'll love it.
Just get it!!
#442
Here's mine finished off now. I have the cowl off to tune the engine, it's running pretty good now. I flew 15 min on about 6oz of gas and no gooey mess to clean up. I changed the wheel to Robart scale wheels with the foam inserts to minimize bounce on the landings. Nice plane. Now I have to hook up the smoke system I picked up the hat at the WWII weekend in Reading,Pa. www.maam.org Great show every June with lots of warbirds.
#443
A friend of mine has tha same plane. I saw in your pics the battery packs on the engine mount. How many weight (lead) did you add to the nose to balance it?
What do you think about a dle30cc?
Thanks.
#444
No lead was needed with the 2 batteries. The 20 flys it well and is scale like at 1/2 throttle. The 30 would be overkill, but if you have it use it, and just throttle back. I would get not use the CA hinges as both my ailerons broke loose in seperate flights and I have now changed all the hinges to nylon pin type hinges epoxied in and pinned with 1/32 music wire through the hinge and the edges of the control surfaces and trailing edges of the wing. Boy it's a little scary flying with one aileron hanging down[X(] I learned to use the rudder early in my training and it sure paid off getting my plane back in one piece. I don't understand why GP makes an IMAA legal plane and then gives you 40 size hardware[>:] Change it out for giant scale hardware.
#446
Ordered a PT-17 Stearman from Tower on Friday and it got here today. After hearing all of the bad covering stories I was surprised to find my plane had perfect covering. I just had to go over a few seams to make sure they were down good and that was it. I'm putting a DLE 20 with a Pitts muffler on it and probably run a Vess 17x6 or 18x6 depending on clearance.
#447
FL
ORIGINAL: SpinnerRow
Regards
Michael
#449
MO
Is this plane suited for short field landings.
My personal field I can fly 60 bipes no problem but there is now way I can land my 30 cc MX there.
I had a H-9 sopwithcamel and landed it fine on my runway,
