Connecting Ailerons On 1/3 Scale Pitts
Has anyone Slaved the top ailerons on the 1/3 scale Great Planes Pitts? If so how did you connect them? Large or small control horns? Horns on leading edge or trailing edge of ailerons? Pics would be great! Any help in this matter is greatly appreciated
Allow me to try to talk you out of that idea. The plane was designed with 4 aileron servos for a reason: At this model size 16lbs plus, you really need the most solid control set-up possible - no shortcuts. The stock ailerons don't have hardpoints in them at the trailing edges (where you'd normally locate the inter-airleron horns), so you'd be hoping the balsa is up to the job. I would strongly discourage this practice in a giant scale plane.
If you want to save some bucks, you can run cheaper ballbearing servos like the Hitec 635, but pls use 4 of them! It would be better even to go w/ 4 Futaba 3001 standard servos running on 6 volts, than to slave the top ailerons to the bottom ones.
TX
DNB,
It's safe to go either way! Mine has been going for two years with lower aileron servos only and has been really quite tight. Here's how: Start with a pair of pretty good servos in the lower wing. (I'm using JR 8231 digitals.) Measure the distance between the mounted horns on the trailing edge of the aileron with the surfaces resting centered. The overall length of each rod assembly will be this measured length. Take two 4-40 quick link threaded rods and discard the quick links. Lay one rod facing one way and the other rod facing the other way. (this makes threads on either end) Sweat solder the entire length so that both rods are now a single unit. Take 1/4" K&S airfoil tubing and push the sweat soldered rod unit into the airfoil tubing so that approximately 1/2 to 3/4" of threads stick out on either end of the rod unit. (It will take pliers to force the rod into the tubing for a great friction fit.) Place a small washer followed by a 4-40 nut with some Locktite on it on both ends. Install ball bearing 4-40 ends on both ends of this rod unit. Install the finished rod unit to the supplied horns placed at the trailing edge of the ailerons with 4-40 cap screws and 4-40 locknuts. (A jamnut can go against the locknuts for added safety.) No slop. No flutter. I am using a Zenoah G-45 with a Zinger 18- 8/14 prop and this thing is ballistic with no flutter or slop. The quad servo set-up is fine also but I never take the plane apart so this works for me. (Don't forget to do the top wing mod and make sure you have the new improved mounting brackets installed on the top center of the wing. The old style crack at the 90 degree bends and you can lose your top wing!) Good luck and happy flying.
Terry
Terry
