CG of Avistar Superstar Select
PA
What is the CG from the wings leading edge back for the Avistar
Superstar Select ? These goofy directions have you draw
lines with a range between, what the heck is that?
FL
the CG on the avistar is at the Spars. Place one finger under each wing at the spars and pick it up.
It should be balanced correctly right out of the box.
Brudford,
The "Avistar" is one plane, and the "SuperStar" is another.
The Avistar is a semi-symmetrical wing and has a CG of 3-1/4"
The "SuperStar" is a flat-bottom wing and has an adjustable CG (wing shift) from:
• SuperStar 40: 3-3/8" to 3-7/8"
3-3/8" for more docile performance,
3-7/8" is more responsive.
• SuperStar 60: 3-7/8"
Note: The Avistars' CG is designed with a .40 engine in mind. If you change the size, the weight will vari and so will the CG.
Any planes Center of Gravity may be altered by shifting the payload (battery, receiver, servos, fuel, etc.).
The wing design should match closely to the designed CG, so you don't want to tweak it too much or the wing won't work as it should.
That my 2¢ worth.
MacAir
That my 2¢ worth.
MacAir
