 .91FS  engine on GP Big Stik >
Old 07-04-2005 | 04:02 PM
Default .91FS engine on GP Big Stik
My LHS gave me a really good deal on a Magnum XL .91RFS and I'm thinking of installing this on my Big Stik .40. As per airplane manual the recommended engine for a four stroke is .60-.80 cu in and an O.S. .70 FS is highly recommended for this plane. I compared the specs between this 2 engines and only a slight difference on weight and RPM range. But the O.S. is about $60.00 more.
I would like to do basic aerobatics with this airplane with unlimited vertical. I'll appreciate it very much if you can give me any inputs.
Old 07-04-2005 | 06:40 PM
Ed_Moorman's Avatar
Default RE: .91FS engine on GP Big Stik
Your only problem is going to be prop clearance. A Mag .91 will be a great power plant, but the landing gear is too short. It barely clears a 13 inch prop. You might want to get an after market gear or one from a Big Stick 60.
You also may need to mount the elevator and/or rudder servos in the rear fuselage for balance.
Finally, you'll need to switch to a larger, .91 size Great Planes engine mount.
