 Best engine for WM Dago Red 46? >
View Poll Results: A poll
YS FZ63S 4-stroke
15.15%
Magnum 70 4-stroke
6.06%
Saito 72 4-stroke
6.06%
Saito 82 4 stroke
18.18%
Magnum 91 4-stroke
3.03%
YS110 4-stroke
51.52%
Voters: 33. You may not vote on this poll
Old 08-06-2005 | 03:48 PM
David Cutler's Avatar
Default RE: Best engine for WM Dago Red 46?
Yes indeed BB the YS110 is the engine of choice at the basin!
Maybe this message should be in the basin thread, but I did some calculations on the theoretical top speed with a 10 inch pitch prop (the 12x10 most commonly used), assuming no slippage (impossible, but it does give a theoretical maximum possible top speed).
It goes like this, assuming the prop pulls the plane forward the 10 inches provided per revolution by the pitch..
10 inch x 11500 RPM (about the norm for a 110 turning a 12x10) = 115000 inches per minute
=11500/63360 miles per minute = 1.81 miles per minute
=1.81 x 60 mph = 108 mph.
How can that be? I'm sure we've clocked one of the warbirds at the basin at over 130 mph.
Where did I go wrong?
-David C.
Old 08-06-2005 | 04:22 PM
David,
If you start with 130mph and back up your calculations we can assume the YS110 unloads in the air to 13728rpm's, seems plausable.
Old 08-06-2005 | 06:00 PM
Yes I agree.
What it also says is that an APC is very efficient, and there isn't much slippage or cavitation.
-David C.
Old 08-06-2005 | 07:21 PM
rare_bear's Avatar
i measured a little toni on the ground with a 12x9 doing 12,500. a 12x10 could prolly do the same. it's quite plausible that the prop unloads 1,000 in the air. i don't think anyone's done any analysis on prop unloading factors other than just the standard guess of 500-1000 rpm's. it may even be higher. would need a laptop computer/sound card/ recorder as the plane flys by (averaging the doppler) to compute the number of power strokes per second.
Old 08-06-2005 | 10:50 PM
I think 12K RPM for YS110 is too much & it will reducr engine life.
I have both YS63S & YS110 on hand & it's hard to made the discussion but I think I'll go for the 63 & trying to put APC 12X8 on it. do you think the 63 can handle the 12X8?
Old 08-06-2005 | 10:55 PM
  #31
ORIGINAL: piper_chuck
Kind of hard to vote in a poll that ends before it started.
Sorry!!
Poll is reset.
Old 08-06-2005 | 11:09 PM
  #32
rare_bear's Avatar
i don't have a 63 so i can't comment.... you can, however, find that information in the owners manual or on-line.
Old 08-06-2005 | 11:25 PM
  #33
Don't be a wuss! Go with the 110, the first post did say "if money was no problem" didn't it?
Old 08-07-2005 | 02:16 AM
  #34
ORIGINAL: BasinBum
Yes, I do have both engines. But I'm wondering the weight & virbation issue of the 110 & I think it will give plenty of stress to the fuse.
I don't need a superfast warbird & if I found the 63 is not good enough for me then I can try the 110.
Old 08-07-2005 | 07:49 AM
  #35
If you don't want speed than use the 63 but I hope you didn't buy the WM for it's scale appearance. As for the plane holding up....that is not an issue, I have seen at least 30 of these planes with a 110 and they hold up just fine to the stress. Seeing several in formation without mufflers (just a straight pipe) is rather fun to watch and a very regular sight at our field.
Old 08-07-2005 | 09:01 AM
  #36
ORIGINAL: BasinBum
I got this plane NIB for US$90 which I don't buy it for the appearance but for the price then I have a new plane to play around.
Old 08-07-2005 | 12:08 PM
  #37
Also, the 110 balances the plane perfectly without any need for any extra weight at the rear, even with the radio battery etc in standard easy to fit positions. In fact the one and only model I have seen with a 46 had to have a lot of weight added to the nose.
No, the YS110 is a perfect fit in every way without the need for any modification.
-David C.
Old 03-08-2006 | 10:31 PM
  #38
My Feedback: (58)
webra speed 55GT with J-tech pitts muffler, 10X8 prop. plenty fast enough for me.
Old 03-26-2006 | 07:32 AM
  #39
O.S. 120 AX APC 13-13 4 blade 8,500 rpm static, 14-14 2 blade 8,700 static.Fuel is YS 20-20.[:-]
Old 03-27-2006 | 05:07 AM
  #40
forestroke's Avatar
priyasman, you have a picture of that beast? that's a lot of engine for a 46 size plane...
Old 03-30-2006 | 11:34 PM
  #41
It's under construction so I will give details when finished. 120 AX is only 2 oz. more than YS 110 (without muffler extention).
Old 03-31-2006 | 09:46 AM
  #42
RedTwilight's Avatar
Ok you guys have peaked my interest in the WM Dago Red model. Does anyone know the link to the World Models website or a place that sells them?
RedTwilight
Old 04-01-2006 | 03:12 AM
  #43
www.airborne-models.com
Old 01-08-2007 | 11:44 AM
  #44
Hisham's Avatar
Guys, any online videos of this .46 WM Dago Red???
Hisham
Old 01-11-2007 | 01:06 AM
  #45
ORIGINAL: Hisham
Hisham
http://www.nanoplanes.net/warbirds-midair-collision.wmv
If that doesn't do it for ya' nothing will.
Bill
Old 01-11-2007 | 01:22 AM
  #46
BTW- almost all of the planes in the video are WM 46 with YS110's.
Old 01-11-2007 | 02:27 AM
  #47
Hisham's Avatar
BillVille
Thanks for the video, infact I have been to this airfield (Apollo)
some time ago, in August 2005.....
http://www.valleyflyers.com/
Watched some pylon races there on the first visit,
on the second one was some free flyers ... Awesome flying field.
Hope to visit again some time in the near future,
Hisham
Old 01-11-2007 | 02:47 AM
  #48
ORIGINAL: Hisham
BillVille
Hisham
It' where I fly... it's safer from shootdowns now that the DX7 is here.
Old 01-11-2007 | 05:33 AM
  #49
Hisham's Avatar
Great Bill...
Maybe we'll meet some day, when I travel
to your side of the globe...
What type of airplanes do you fly ??? any pix.?
Hisham.
