kyosho cap 232 question
What should be the motor incidence on this plane ?
The wing is a tad positive in reference to the stab...
I called Great Planes and was told that this was normal.
For the motor I was thinking a bit of down and a bit of right...
Comments ?
Aviateur
Comments ?
Aviateur
Well, normally down and a bit to the right is what you're looking for, but because of the CAP's high stab you actually want zero degrees for thrust line, or even positive... Right thrust is still correct though....
Mount the engine as per instrutions and you will be alright!
I have 2 Kyosho CAPs and I haven't found it necessary to make any changes except for fiddling with the C.G.
