Can you
Old 10-10-2005 | 06:34 PM
Default Can you
can you make the futaba 7 ch heli system work with planes.
Old 10-10-2005 | 08:36 PM
Default RE: Can you
Yes, the 7CHP can be used with airplanes, just need to go through the programing to put it from heli mode to acro mode. It's fairly easy to do. You don't have to worry about reprograming it back, for you can program several different models, and switch to the model you want on the screen.
Old 10-10-2005 | 08:47 PM
exeter_acres's Avatar
Default RE: Can you
about the only difference is ratchet throttle and switch position......
AFAIK
Old 10-11-2005 | 06:11 PM
Default RE: Can you
Thanks alot for the help!! That was a question ive been waiting to get answered for along time.
