 H9 Twst aileron help. >
Old 11-08-2005 | 11:51 PM
Default H9 Twst aileron help.
Iv been having a hard time ajusting the ailerons to nautral. Iv got every thing else ready for flight but i just cant get the ailerons set right, How did you people do it on your twist?
Old 11-09-2005 | 12:53 AM
Default RE: H9 Twst aileron help.
Nutin2it,
I assume that you are talking about how to line them up with nothing to reference. I taped a ruler on each flat wingtip so that one edge of the ruler was lined up with the leading and trailing edge centers (in other words down the center of the wing tip) and so it stuck out past the aileron on each side. Then it was easy to adjust them both to neutral relative to the wing and also to insure that they matched each other. You could use a piece of balsa stock or whatever you had as long as it was straight.
Greg
